Bug report: crash after switching between screens
Activity › Forums › Astrosoftware › Astro Pixel Processor › Bug report: crash after switching between screens
  • #15125
    Wang
    I have two monitors connected to my Mac. The two have different resolutions. Dragging APP between the two monitors is OK and would not cause troubles.
    On the other hand, APP would crash when I turn one monitor (the one with APP) off and the system forces APP to move to the monitor that’s on. The forced movement between monitors works totally fine for all my other applications. All of them get pushed to the monitor that is on smoothly, and only APP crashes.  I can’t tell whether the crash is triggered by the forced movement, or by the difference in screen resolution, as I do not have two screens of the same resolution.
    Cheers,
    Wei-Hao
    #15126
    Wang
    Sorry.  Further tests show that it has nothing to do with moving APP’s window from one monitor to the other.  Even if it stays in the same window, just shutting down the other one can trigger a crash.
    #15135
    Thank you @whwang,
    I will test this using my macbook with attached monitors and hopefully fix this.
    Added to RFC
    Mabula
    #15145
    Wang
    Does APP automatically send you (or save locally) a crash report every time it is crashed or forced to terminate?  It should be useful.
    #15153
    @whwang, not yet, but it’s on my list to set logging on in APP’s configuration menu. I’am also planning to show console output while APP’s working ?
