bugs and a question
Activity › Forums › Astrosoftware › Astro Pixel Processor › bugs and a question
  • #13320
    some more bugs and a question:
    (using version 1.034.1 8GB on Windows 10)
    BUG: Tabs are still available during progressing pop-ups (eg during analyse stars). I’m unsure if this is a bug though…
    BUG: Many Java errors were generated when cancelling the progress popup during analyse stars (see picture).
    BUG: selecting starmap from the dropdown at the top on an RGB combined image causes a java error.
    BUG: unchecking files in the filelist during saving registration files is causing java error.
    BUG: after presing calculate (and not create) in Cobine RGB and then save image on the right panel a java error is generated.
    BUG: In the upper left corner mem remains on 8192/8192 all the time (bug introduced in this version?)
    BUG: when loading files from a sub-directory in the selected work directory the sub-directory is not remembered in the filelist resulting files not being able to load.
    Question: What is the purpose of all the tickboxes for the loaded master flat/bias/darks and all the created files in the filelist?
    #13352
    Thanks again Rob for your bugs ?
    “BUG: Tabs are still available during progressing pop-ups (eg during analyse stars). I’m unsure if this is a bug though… ”
    No, no Bug, tabs are available, bu the buttons should be disabled in the tabs. I need to double check if all buttons are disabled when a task runs.
    “BUG: Many Java errors were generated when cancelling the progress popup during analyse stars (see picture). ”
    I’ll put this on the RFC list at the top.
    “BUG: selecting starmap from the dropdown at the top on an RGB combined image causes a java error.”
    Well found, when working in a tool, this dropdown shouldn’t be available, so I propose to disable the dropdownbox when working in a tool
    “BUG: unchecking files in the filelist during saving registration files is causing java error.”
    Okay, I will try to replicate this, haven’t thought of this previously.
    “BUG: after presing calculate (and not create) in Cobine RGB and then save image on the right panel a java error is generated.”
    Okay, need to replicate this as well ?
    “BUG: In the upper left corner mem remains on 8192/8192 all the time (bug introduced in this version?)”
    No not a bug, I changed memory settings of the application to claim a fixed amount of memory to work with instead of letting the application manage it’s memory use. Maybe this is not necessary.  I need to do further testing. I added it to the RFC list to do more work here.
    “BUG: when loading files from a sub-directory in the selected work directory the sub-directory is not remembered in the filelist resulting files not being able to load.”
    Need to check this as well, have never experienced anything like this before..
    #13355
    “Question: What is the purpose of all the tickboxes for the loaded master flat/bias/darks and all the created files in the filelist?”
    For images that are stated as processed, there is no function.
    For all lights, bias, dark, flats, master calirbation frames and BPM, the boxes can be used to deselect images and remove them from the file list. If you deselect a master calibration frame, it wont be applied to your lights in a following process.
    A deselected light won’t be used in a process  from 2) to 6).
