Master bias, dark, flats
Activity › Forums › Astrosoftware › Astro Pixel Processor › Master bias, dark, flats
  • #12741
    I have a library of master bias, dark and flats for each filter (L, R, G , B, Ha, OIII and SII) which I alway use.
    How should I load these?
    I’m currently loading them through the 1) LOAD page and then press in the 2) CALIBRATE phase create calibration masters and then save calibrated frames but I’m wondering if this is the intended procedure?
    #12748
    I had those as fits as well, but it’s better to reprocess them using APP. Since mine came from RAW format and I didn’t save that, I had to remake them. You can just select the seperate CCD frames and make new masters. It then, I think, properly recognizes them as masters.
    #12761
    If you aren’t using masters from RAWs then this is correct Rob. Just load your old masterdark (from PI) as a dark and create masterdark, then APP wil properly make a masterdark of your old masterdark and it will perfrom analysis on it (check fits header by using details selectbox above image viewer). This also applies to your old masterbias and masterflat.
    Load them as a single calibration frame fo the right type and create calibration frames.
    One extra tip. Use your masterdark to create a bad pixel Map for your sensor as well ? set the bad pixel map setting at: hot pixels kapp at 2 to start with. This is similar to cosmetic correction in PI I believe.
