Question on workflow
Activity › Forums › Astrosoftware › Astro Pixel Processor › Question on workflow
  • #13394
    Van den Broek
    So, can you just load up the lights + calibration files and then go to step 6,
    will all steps be executed with the settings selected? I see that after my lights B F and CA are there, but my CA files where not created, is that done in memory?
    /Yves
    #13412
    Hi Yves, calibration of your data is done while the files are loaded, so there is no need to save the calibrated frames. ( but I always do for future projects, I don’t keep the calibration frames..)
    If you have loaded your lights and master calibration files, you will want to check the quality of your calibration by setting the image viewer to the l-calibrated mode instead of linear mode ?
    If you then click on one of your lights in the file list, it is loaded and calibration is applied, so you’ll see the calibrated image in the image viewer.
    Personally, I always verify calibration before starting with 3) star analysis.
